TouchTheSky
Visits: 4.6K
+x+x+x+x+xHi everyone. I have been able to complete my Stratux with flarm setup. Have not been able to test the Flarm receiving yet as the snow here in Norway have put a damper on glider flying but logs indicate that it works. I ended up copy/paste the item list form stratux.me to ebay and order everything from there. 3D printed my own case as I was not happy with the one offered, I made my own remix of this one: https://www.thingiverse.com/thing:1707442I will sit down and make a step by step guide to what I did and post it here in a few days. My confusion in the start was the MPU9250+BMP280 sensor. I read some old posts from before or as this was released that confused me. It took me some time to understand that
as for weather, I find using 3/4G to be more than good enough where I fly, the easiest way to keep your 3g connection while connected to the Stratux wifi is to switch form DHCP to Static IP on your mobile device and remove the Gateway address. Tested this on both iphone and ipad.
-alex
Hi all. After doing the above, to get the Stratux working with flarm based on this post: https://www.reddit.com/r/stratux/comments/6pa2nj/flarm_receiver_functionality/I did the following after loading the Stratux image on the SD card and starting the Pi: //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo raspi-config //expand file system and reboot //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo ifup eth0 //Log in using SSH to eth0 IP address sudo su systemctl start ntp service stratux stop sudo apt-get update sudo apt-get install libconfig9 sudo apt-get install libjpeg8 wget https://storage.googleapis.com/golang/go1.9.linux-armv6l.tar.gzsudo tar -C /root -xzf go1.9.linux-armv6l.tar.gz cd /root/stratux export PATH=/root/go/bin:${PATH} export GOROOT=/root/go export GOPATH=/root/go_path cd / rm -Rf /root/stratux cd && git clone https://github.com/WiringPi/WiringPi.git && cd WiringPi/wiringPi && make static && make install-static cd && git clone https://github.com/0x74-0x62/stratux.git && cd stratux && git checkout remotes/origin/devel/flarm_receiver && make && make install //Long Wait service stratux start //Finnish Just one note: the current FLARM executable produces an (ignorable) error message with a blinking green LED. The developer is already working on it. Quick question, have you replaced the 978 mhz antenna or are you using the one that came with the Stratux kit? I replaced it with the following: https://www.amazon.de/dp/B072BMBXMH/_encoding=UTF8?coliid=I3RORSKO1YA0UV&colid=3GGSQDSNIAKZP&psc=0 I am still wondering why no one is installing a recommended ground plane, see here: http://stratux.danmurray.net According to Dan Murray, the benefit of the ground plane is negligible, compared to the potential risk of short-circuiting the Pi board.
popov
Visits: 4
+x+x+x+x+x+xHi everyone. I have been able to complete my Stratux with flarm setup. Have not been able to test the Flarm receiving yet as the snow here in Norway have put a damper on glider flying but logs indicate that it works. I ended up copy/paste the item list form stratux.me to ebay and order everything from there. 3D printed my own case as I was not happy with the one offered, I made my own remix of this one: https://www.thingiverse.com/thing:1707442I will sit down and make a step by step guide to what I did and post it here in a few days. My confusion in the start was the MPU9250+BMP280 sensor. I read some old posts from before or as this was released that confused me. It took me some time to understand that
-alex
Hi all. After doing the above, to get the Stratux working with flarm based on this post: https://www.reddit.com/r/stratux/comments/6pa2nj/flarm_receiver_functionality/I did the following after loading the Stratux image on the SD card and starting the Pi: //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo raspi-config //expand file system and reboot //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo ifup eth0 //Log in using SSH to eth0 IP address sudo su systemctl start ntp service stratux stop sudo apt-get update sudo apt-get install libconfig9 sudo apt-get install libjpeg8 wget https://storage.googleapis.com/golang/go1.9.linux-armv6l.tar.gzsudo tar -C /root -xzf go1.9.linux-armv6l.tar.gz cd /root/stratux export PATH=/root/go/bin:${PATH} export GOROOT=/root/go export GOPATH=/root/go_path cd / rm -Rf /root/stratux cd && git clone https://github.com/WiringPi/WiringPi.git && cd WiringPi/wiringPi && make static && make install-static cd && git clone https://github.com/0x74-0x62/stratux.git && cd stratux && git checkout remotes/origin/devel/flarm_receiver && make && make install //Long Wait service stratux start //Finnish Just one note: the current FLARM executable produces an (ignorable) error message with a blinking green LED. The developer is already working on it. Quick question, have you replaced the 978 mhz antenna or are you using the one that came with the Stratux kit? I replaced it with the following: https://www.amazon.de/dp/B072BMBXMH/_encoding=UTF8?coliid=I3RORSKO1YA0UV&colid=3GGSQDSNIAKZP&psc=0 I am still wondering why no one is installing a recommended ground plane, see here: http://stratux.danmurray.net According to Dan Murray, the benefit of the ground plane is negligible, compared to the potential risk of short-circuiting the Pi board. Got to ask just to be sure as English is not my native language: Do you mean that the ground plane help prevent short-circuiting or increases the risk of short-circuiting?
TouchTheSky
Visits: 4.6K
+x+x+x+x+x+x+xHi everyone. I have been able to complete my Stratux with flarm setup. Have not been able to test the Flarm receiving yet as the snow here in Norway have put a damper on glider flying but logs indicate that it works. I ended up copy/paste the item list form stratux.me to ebay and order everything from there. 3D printed my own case as I was not happy with the one offered, I made my own remix of this one: https://www.thingiverse.com/thing:1707442I will sit down and make a step by step guide to what I did and post it here in a few days. My confusion in the start was the MPU9250+BMP280 sensor. I read some old posts from before or as this was released that confused me. It took me some time to understand that
-alex
Hi all. After doing the above, to get the Stratux working with flarm based on this post: https://www.reddit.com/r/stratux/comments/6pa2nj/flarm_receiver_functionality/I did the following after loading the Stratux image on the SD card and starting the Pi: //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo raspi-config //expand file system and reboot //Log in using SSH over wifiHotSpot or HDMI/Keyboard sudo ifup eth0 //Log in using SSH to eth0 IP address sudo su systemctl start ntp service stratux stop sudo apt-get update sudo apt-get install libconfig9 sudo apt-get install libjpeg8 wget https://storage.googleapis.com/golang/go1.9.linux-armv6l.tar.gzsudo tar -C /root -xzf go1.9.linux-armv6l.tar.gz cd /root/stratux export PATH=/root/go/bin:${PATH} export GOROOT=/root/go export GOPATH=/root/go_path cd / rm -Rf /root/stratux cd && git clone https://github.com/WiringPi/WiringPi.git && cd WiringPi/wiringPi && make static && make install-static cd && git clone https://github.com/0x74-0x62/stratux.git && cd stratux && git checkout remotes/origin/devel/flarm_receiver && make && make install //Long Wait service stratux start //Finnish Just one note: the current FLARM executable produces an (ignorable) error message with a blinking green LED. The developer is already working on it. Quick question, have you replaced the 978 mhz antenna or are you using the one that came with the Stratux kit? I replaced it with the following: https://www.amazon.de/dp/B072BMBXMH/_encoding=UTF8?coliid=I3RORSKO1YA0UV&colid=3GGSQDSNIAKZP&psc=0 I am still wondering why no one is installing a recommended ground plane, see here: http://stratux.danmurray.net According to Dan Murray, the benefit of the ground plane is negligible, compared to the potential risk of short-circuiting the Pi board. Got to ask just to be sure as English is not my native language: Do you mean that the ground plane help prevent short-circuiting or increases the risk of short-circuiting? No, the other way round. It is a risk to use the ground plane.
PaulSS
Visits: 3.2K
From what I understand, those antennas are end fed dipoles and, therefore, don't need a ground plane. You can attach them directly to an ADSB dongle and no other hardware is required.
TouchTheSky
Visits: 4.6K
+xFrom what I understand, those antennas are end fed dipoles and, therefore, don't need a ground plane. You can attach them directly to an ADSB dongle and no other hardware is required. Thank you this is very helpful information.
Kevin Wolters
Visits: 12
Hi all. So obviously i also want to use Stratux to connect with my Skydemon.
I am a little bit lost after reading all the forum content. Should i be fine when i order (List from Stratux.me) :
- Raspberry Pi 3 Motherboard. - Pre-programmed SD card with Stratux software. - Stratux 1090ES & UAT - Radios and High Gain Antennas. - Stratux Case with Fan, White ABS. - Slim battery with cable. - GPYes/internal - Stratux AHRS Sensors and Fan Controller / Raspberry Pi MPU9250+BMP280.
I live in the Netherlands and i would love to see as traffic as the weather. Are there any montly/yearly payments requested to keep the system online?
Btw. i use my Samsung Galaxy S8+ with Skydemon/
Thanks in advance!
Cheers, Kevin Wolters
TouchTheSky
Visits: 4.6K
+xHi all. So obviously i also want to use Stratux to connect with my Skydemon. I am a little bit lost after reading all the forum content. Should i be fine when i order (List from Stratux.me) : - Raspberry Pi 3 Motherboard. - Pre-programmed SD card with Stratux software. - Stratux 1090ES & UAT - Radios and High Gain Antennas. - Stratux Case with Fan, White ABS. - Slim battery with cable. - GPYes/internal - Stratux AHRS Sensors and Fan Controller / Raspberry Pi MPU9250+BMP280. I live in the Netherlands and i would love to see as traffic as the weather. Are there any montly/yearly payments requested to keep the system online? Btw. i use my Samsung Galaxy S8+ with Skydemon/ Thanks in advance! Cheers, Kevin Wolters This should work right away if (unlike in Germany) the 978 MHz is used for UAT including weather. I am only aware of the UK 978 MHz UAT weather trial where SD is involved but otherwise I am not so sure. There are no montly/yearly payments at all involved. I just built my second Stratux which includes FLARM instead of UAT, using the same hardware but slightly modified Stratux software.
Kevin Wolters
Visits: 12
Thanks for your quick reply.
Which do you prefer? UAT or FLARM?
Cheers
TouchTheSky
Visits: 4.6K
This is no question for me, there is no UAT here in Germany and I’m afraid also not in Netherlands. Not sure about FLARM ...
Kevin Wolters
Visits: 12
Today i received my parcel from the USA!  but unfortunately i do not receive any UAT signals.
I saw a post about this antenna:
Does this one also requires a new USB receiver? or can i just simply screw the antenna on the 978Mhz receiver?
Thanks!
