Sebastian S.
Visits: 0
Hi, I am a new user of SD, formerly JeppFD MFD and I want to know if it is enough to start the flight with the relating button and the the logbook is active with counting the Off Block time, flight time and so on, like in other Apps or do I have to go to the menu " start loggging"? Thanks, Sebastian
Sebastian S.
Visits: 0
Thanks for your fast answer, perfect if it has the the speed monitoring and so start logging. I have read the manual, but this isn't exactly described, so again thanks. Sebastian
Posts: 8.3K,
Visits: 9.8K
SkyDemon logs your flights automatically by detecting your takeoff and landing. You can start the logging earlier though, and finish it manually, if you'd like to log more than just the flight time (e.g. engine time).
alexis.hellen@gmail.com
Visits: 753
+xSkyDemon logs your flights automatically by detecting your takeoff and landing. You can start the logging earlier though, and finish it manually, if you'd like to log more than just the flight time (e.g. engine time). Hello "forumers", is there a possibility now to export data from a flight, such as a *.csv or otherwise from SD to import in a pilot logbook, or excel file? Iread that someone in this thread managed to import it in a pilot logbbok, but I don't understand how. Cheers, Alexis
spaltchr
Visits: 11
it would be really great if the output would be more than just flight time. i guess many of us if not even a majority logs block time. so getting the times as follows would be really helpful:
off block takeoff landing on block
flighttime total time
what do you think about that? an integration on top of the flightlog would be great.
Posts: 8.3K,
Visits: 9.8K
SkyDemon will already do that. It automatically starts logging when you take off but you can start logging earlier, if you like, at a moment of your choice. Just use the option from the in-flight menu.
spaltchr
Visits: 11
dear tim
as i mentioned many of us need the off- and on-block times. so why don't log that time automatically, too? technically it is possible. i would really appreciate that and i'm sure there will be lots of others, too.
you have such a cool layout for the pilot log witch all those fields to fill in on top. wouldn't it be great to have like a red line through those logs, maybe fill in those fields automatically during the process of the flight and get the same handy layout for the log and debriefing pack?
best regards chris
Posts: 8.3K,
Visits: 9.8K
It isn't possible to automatically log the on and off block times. You cannot simply detect movement because people frequently move around (walking out to their aircraft etc) in flying mode.
I'm afraid I have no idea what you're referring to in your second paragraph; if you have a suggestion for a new feature the Suggestions forum is a good place to try it.
spaltchr
Visits: 11
+xIt isn't possible to automatically log the on and off block times. You cannot simply detect movement because people frequently move around (walking out to their aircraft etc) in flying mode. I'm afraid I have no idea what you're referring to in your second paragraph; if you have a suggestion for a new feature the Suggestions forum is a good place to try it. Hmm ok... It's a pity because others realised that function:  Me personally never had the problem of walking around in flight mode. And i really don't want to go back to that other solution. SD is so much more innovative, user friendly, much richer in functions and listens to the community! Would you consider to ask other users about that or are you just saying "no"? Maybe a poll: "What time do you need to be logged for your Logbook: 1. Flighttime 2. Blocktime?" could be something, isn't it? My second paragraph should have been a compliment first of all for the feature "Pilot log". And then my suggestion was to rearrange to information on top of the Debriefing pack in a similar way to make the time-related informations easier to read:   I brought that here, because it is related to my first point. It only makes sense when realising an automatic block-time-feature, maybe even accessible already when in flight mode... Best regards Chris
jfw
Visits: 485
Regarding the logging of the blocktime, I just manually start the logging of SD when starting the motor and stop it manually when stopping the motor. SD has thus all the info as it detects the take-off and landing and records it separately.... Not sure how you want to detect the blocktime either.
Hope this helps.
Br, J
