The connection to your gps has been lost, message
nkt2000
nkt2000
Posts: 23, Visits: 128
Just an update: I just could not get my xgps150 to provide data to Skydemon even though it was showing on two different position data apps. Eventually gave up and was contemplation buying a Pilotaware device instead. However, next flight and everything worked fine. The only thing I had not done whilst trying to sort this out was reboot the iPad mini. Did that before next flight and, hey presto, everything working again. As the gps was providing data to the iPad but not to skydemon, I suspect that a glitch had got in somewhen that cleared itself by a reboot. Wish I had thought of that during the original flight.
Nkt
Thomas Leaver
Thomas Leaver
Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)Too Much Forum (620 reputation)
Posts: 9, Visits: 0
Excellent....thank you very much for that and apologies for all the confusion! Much appreciated!
SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)SkyDemon Team (636K reputation)
Posts: 7.8K, Visits: 8.5K
Thomas, this entire problem is occurring because you have told SkyDemon to connect to your GDL90-compatible traffic receiver when you have no such device. So of course it gives up and tells you it cannot connect to that device.
Please select "none" as you have suggested above. Your Garmin GLO is a standar‌d Bluetooth GPS receiver and you do not need any special settings within SkyDemon to use it. Just press Go Flying and that's it; it will work as long as it's been paired correctly.‌
T67M
T67M
Posts: 206, Visits: 3.2K
It may be different on an iPad, but I would suggest just selecting "location services" in the Go Flying menu on SkyDemon.
Thomas Leaver
Thomas Leaver
Posts: 9, Visits: 0
Perhaps I should select "none" under connectivity options on settings menu?
Thomas Leaver
Thomas Leaver
Posts: 9, Visits: 0
Good question. That is what appears on connections menu page. I only have the Garmin GLO. So GDL90 was what I thought SkyDemon called Garmin GLO. If not, then I have no idea where that came from. Will try and delete it and start over..... thanks.
Thomas Leaver
Thomas Leaver
Posts: 9, Visits: 0
Yes. Connected by Bluetooth on both iPad mini and android phone.
T67M
T67M
Thomas Leaver - 6/28/2017 5:06:55 PM
Actually, menu states, " use location services" and " GDL90". One must be selected and, if GDL90 selected, menu pops up saying cannot establish connection or words to that effect.
Caveat: I don't have a GLO not an iPad.
Question‌:‌ why if you have a Garmin GLO which links to the iPad location services are you telling SkyDemon to use a GDL90 device which you don't have?
Gerhard66
G
Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)Too Much Forum (5.3K reputation)
Posts: 157, Visits: 335
Maybe worth to consider:
I had severe EMC problems with a Chinese 12V/24V to 5V-USB plug in adapter.
Radio Com was impossible, but I didn't check it with a BT connection, which could have been also disturbed.
Changing to a different make solved the problem.
Mike McPherson
Mike McPherson
Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)Too Much Forum (5.2K reputation)
Posts: 47, Visits: 141
have you connected your wifi to that device first?
o‌f course that may be a red herring
_______________________________
Mike McP G-BHLX SD 3.8.1 iPad retina
