What's here SD 3.8.1 PC Win 10
Peter Baron
Peter Baron
Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)Too Much Forum (320 reputation)
Posts: 3, Visits: 3
I use SkyDemon on a Windows 10 PC and a pair of iPads.  The "What's here" function on iPad is excellent, but the implementation on PC has two niggles for me:
1‌.  It pops up whenever the cursor stops moving.
T‌his is a pain from a usability perspective; most of the time I want to see the map, not "What's here", so every move of the mouse must be followed by a click to remove the unwanted information box.  This differs from the behaviour on iPad, where you must do something to make the box appear - ergonomically the right way ‌around.  It would be better, and more consistent, to make "What's here" on the PC require a mouse click, just as it requires a screen tap on a tablet, IMHO.
2‌. The fonts on the PC version are not well rendered.
T‌he iPad version uses nicely rendered fonts, readable, elegant, just what you'd expect.  The PC version doesn't and isn't.  I freely admit that this is a minor niggle, but ‌the aesthetics of SkyDemon is one of its strong points.  I suspect someone will tell me that in the PC version, the "What's here" box is rendered in the same way as all the other map text, which I can believe, but the ratty anti-aliasing is more noticeable against the plain white background of the "What's here" box and there is an expectation that although the map is a graphic and the labels can be a bit rough around the edge,  in this context text is text and should be treated accordingly.
jfw
jfw
Posts: 134, Visits: 485
peterb - 6/8/2017 1:55:31 PM
Umm.  Up to a point Lord Copper.  I'm used to tooltips appearing when the cursor is over a tool, but defining the entire working area of a window as a "tool" seems to be stretching the term a bit.  By analogy, the context menu in the typical office application only appears when you right click in the document.  MS Word with menus and information appearing every time the user leaves the pointer in the active window would not be popular.  Having to click to make the what's here disappear or quickly put the cursor into one of the supporting panes is, er, a pain.
R‌egarding the rendering, if it's the same throughout, I'll try tweaking ClearType.
Personally I would also prefer to have the "What's Here" via right click
jfw - 6/9/2017 7:54:39 AM
+1
6575, SD 4.2.2
George Reid
George Reid
Posts: 113, Visits: 1.6K
Sky Painter - 6/9/2017 1:29:19 PM
+1
+1
George E A Reid
peterb - 5/31/2017 8:42:52 AM
Tim Dawson - 6/5/2017 3:11:52 PM
                     +1
                         +1
GEAR - 6/9/2017 4:34:17 PM
     Count me in. +1
efrenken - 6/10/2017 5:09:47 AM
Tim Dawson - 6/12/2017 10:12:10 AM
jfw - 6/12/2017 12:12:26 PM
ajmc - 6/14/2017 10:34:05 AM
T67M - 6/14/2017 10:55:32 AM
