Terrain warning
SkyDemon will warn you about an obstacle if by the time you get there, with your current trajectory (including vertical) you would be below a safe height above it, simple as that.
As others have said, it would be worth checking the virtual radar or your GPS altitude when this happens so you can get a feel for why it's happening. You may also wish to reduce the time-to-threat required to trigger the warning, which is set at three minutes by default.
Paul_Sengupta
P
Posts: 29, Visits: 218
Other people have reported when playing back tracks from SD that have been taken using a built in tablet GPS, that their altitude drops to zero at seemingly random times during the flight. This can be seen on the elevation display at the bottom. Do a review of the flight to see if this is/was the case. I can only think that the built in GPS on tablets is losing the altitude somehow, maybe through a drop out of number of visible satellites. I don't seem to get it, but I have a canopy aeroplane. I also these days generally use the WAAS/EGNOS enabled GPS on my PilotAware as my GPS source.
Skyboy999
Skyboy999
Posts: 58, Visits: 239
Plausible. I'll check. But, if this the case, it seems a bit over sensitive as I'm sure any descent in such cruise would be temp due to turbulence or my clumsy flying.. Perhaps the SD guys will confirm. Thanks
George Reid
George Reid
Posts: 113, Visits: 1.6K
When you get this alert I suggest that you look at the virtual radar display.  You may be descending at that instant and SD is warning you of a possible problem if you continue on your current descent trajectory.
George E A Reid
T67M
T67M
Posts: 206, Visits: 3.2K
Skyboy999 - 4/23/2017 8:21:29 AM
Quite often get pop up warning terrain e.g. "Climb above 1500'" but already flying much higher than that. Why is this?Thanks
Good question. I've often wondered this myself, but by the time I've landed, I've forgotten to enquire. It's very annoying when flying in the cruise at 3,000' to get the "bark bark bark" audio alert to look down and see  "antenna ahead, climb above 1,200'"
Skyboy999
Skyboy999
