By Tim Dawson - 4/24/2017 9:08:48 AM
            SkyDemon will warn you about an obstacle if by the time you get there, with your current trajectory (including vertical) you would be below a safe height above it, simple as that.
  As others have said, it would be worth checking the virtual radar or your GPS altitude when this happens so you can get a feel for why it's happening. You may also wish to reduce the time-to-threat required to trigger the warning, which is set at three minutes by default.
            By Skyboy999 - 4/23/2017 8:21:29 AM
            Quite often get pop up warning terrain e.g. "Climb above 1500'" but already flying much higher than that. Why is this? Thanks
