Problem with opening terminal charts from AIP-Germany
Mike Stueber
Mike Stueber
Posts: 54, Visits: 196
Hallo guys,
I'm using an iPad mini 1 with iOS 9.3.5 .
All works fine and SkyDemon is running without problems.
I can open very large pdf-files (not using SkyDemon) without problems).‌
But now the following problem occurs:
When opening e.g. "EDDS Terminal chart" the pdf doesn't open and the screen is going to black.
The same with the terminal charts of EDDF and EDDH.
When I open the arrival-charts of the international airports, the pdf opens and all is fine up to the moment I'm zooming in very intensive.
In all other cases the documents of the smaller airfields I can handle without problem. Zooming in- and out occurs no crashes.
Is someone still using iPad mini 1 and the German AIP and can try it out?
Many thanks
Kind regards,
Mike‌‌‌‌‌‌‌‌‌
Edited 1/25/2017 2:56:34 PM by Mike Stueber
matthiasr
m
Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)Too Much Forum (279 reputation)
Posts: 3, Visits: 0
‌I too am still using an iPad Mini 1. I just checked and I have the identical behavior.
‌If I copy the PDF to iBooks, iBooks actually crashes when trying to open it -- so I guess the black, grey, black, loading... cycle we see in SD is just SD repeatedly trying to open the PDF.
‌Unfortunately, this looks like we have to shop for a new iPad in the near-to-mid future..
‌Best regards
‌Matthias
‌EDIT: Low memory warning/crash in the iPad log...
Edited 2/1/2017 5:01:33 PM by matthiasr
