Speed of screen build-up
FaRu1
FaRu1
Posts: 35, Visits: 47
Dear Skydemon team.
although I like your product very much, I have a bit of a problem with one point:
Building up the screen after manually moving it or changing the scale takes too much time.
- I am using SD version 3.6.4.20819
- Samsung Galaxy Tab-S with 2GB RAM (SM-T700), Android 5.02
- Two products installed: Skyguide (CH) and DFS (GE)
- Multiple AIPs installed (but is that influencing the speed? should not, as that is off-line pdf-information opened only on demand)
- I know that displaying terrain information requires a lot of time - I usually switch it off, as it takes about 10-12 seconds screen reproduction time.
- Weather information display is switched off
- it still takes 3-5 second to build up the full screen information after a manual move or scale change
- Ending all other application (apps) before opening SD does not really bring much of improvement
How could I best improve the speed of image build-up?
Thanks for helping responses. (Please don`t tell me to buy IOS products)
F.
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
Tim Dawson - 9/30/2016 4:06:01 PM
We make our recommendations based on our support burden. Android gives rise to far, far more problems than iOS does. Your average iOS user is at least 300% as delighted with their hardware purchase as your average Android user*. I'm not saying it doesn't have its place, mind you.
* anecdotally
I originally bought the iPad because I wanted to use Jeppesen FliteDeck VFR, which has better ground detail than SD. However, after being disgusted by the iPad's poor outdoor performance I knew I had to go to android. Jeppesen doesnt support android so I switched to SD, and I really like it. The point is there are some of us that use SD primarily because it supports android, so it'd be a shame if the android version is being treated as just an afterthought or is actually a shoddy port of the iOS version.
FaRu1 - 9/16/2016 9:59:08 AM
Tim Dawson - 9/16/2016 2:24:52 PM
FaRu1 - 9/18/2016 10:06:25 AM
Tim Dawson - 9/19/2016 10:28:18 AM
Easy Cruising - 9/30/2016 9:28:34 AM
MikeTwoOne - 9/30/2016 3:48:53 PM
efrenken - 10/1/2016 8:13:46 AM
Easy Cruising - 10/1/2016 3:33:02 PM
Tim Dawson - 10/4/2016 10:31:46 AM
JanR - 10/4/2016 1:31:59 PM
Tim Dawson - 10/4/2016 1:57:27 PM
JanR - 10/4/2016 3:26:54 PM
Tim Dawson - 10/4/2016 4:27:29 PM
tnowak - 10/5/2016 7:41:34 AM
Tim Dawson - 10/5/2016 11:13:19 AM
