rikur
rikur
Posts: 132, Visits: 632
(updated August 2018)
For High Sierra:
Known issues:
How does it work?:
guille
guille
Posts: 149, Visits: 2.4K
Hi, I just tried it, and there is a problem with the menus, if I clique "routes" the window with the routes appears... and disappears quite quickly, the same with the others.
Thanks for the work done to be able to use SD directly on a Mac ! If there is an explanation to the problem I found, I will try to use it.
Guillermo
rikur
rikur
guille (12/2/2015)
Guillermo
Try the following:
 - locate Skydemon in the Applications folder, Right Click, and select "Show Package Contents"
 - This should reveal a program called "Wineskin" - double click this
 - This should present a set of four buttons, click "Set Screen Options"
 - Click 'Use Mac driver instead of X11" and click done
 - Then try again.
Another trick to resolving display bugs in Wineskin is to try resizing the programme window
guille
guille
Thanks ! Now it works fine, and I had no problems concerning charts.
Guillermo
rikur
rikur
guille (12/2/2015)
Guillermo
phew .... I was beginning to think problems were arising as quickly as I was fixing them ;-)
rikur - 11/20/2015 9:44:00 PM
Bajab - 11/21/2015 7:19:48 PM
rikur - 11/21/2015 7:25:13 PM
rikur - 11/22/2015 8:57:10 PM
rikur - 11/23/2015 6:34:45 PM
C82R - 11/28/2015 9:23:29 PM
rikur - 11/29/2015 7:52:26 AM
rikur - 11/29/2015 8:53:56 PM
                 hii
                 hii
rikur - 12/2/2015 10:30:52 AM
guille - 12/2/2015 6:12:04 PM
rikur - 12/2/2015 6:13:26 PM
Gernot - 12/6/2015 1:30:12 PM
rikur - 2/4/2016 4:08:08 PM
reimomo - 3/3/2016 7:50:58 PM
reimomo - 3/3/2016 7:52:07 PM
rikur - 5/5/2016 10:41:45 AM
guille - 5/20/2016 7:47:28 AM
rikur - 5/20/2016 8:49:48 PM
guille - 6/2/2016 12:09:59 PM
rikur - 6/2/2016 7:26:25 PM
rikur - 8/2/2016 6:54:12 AM
ADW666 - 9/12/2016 5:15:21 PM
rikur - 9/12/2016 9:18:12 PM
ADW666 - 9/12/2016 9:22:32 PM
                     + x [quote] [b] ADW666 - 9/12/2016 9:22:32 PM [/b] +...
rikur - 9/12/2016 9:49:55 PM
rikur - 9/17/2016 11:22:51 AM
KFL - 10/8/2016 7:21:31 AM
rikur - 10/16/2016 9:56:20 AM
                     + x [quote] [b] Cessnaoui - 10/17/2016 2:45:57 PM [/b]...
rikur - 10/17/2016 2:54:31 PM
     Any new?
rikur - 12/6/2016 1:11:19 PM
rikur - 2/22/2017 1:16:32 PM
on5ap - 2/22/2017 1:49:37 PM
rikur - 3/18/2017 8:52:32 PM
nestor - 4/10/2017 8:49:14 AM
rikur - 4/10/2017 8:53:43 AM
rikur - 4/29/2017 1:51:12 PM
on5ap - 5/1/2017 10:26:57 AM
rikur - 5/1/2017 3:39:14 PM
on5ap - 5/26/2017 10:47:14 AM
IvanS - 5/22/2017 4:36:23 PM
rikur - 6/25/2017 4:31:58 PM
rikur - 6/25/2017 7:25:49 PM
                         Yeah, I see. I've just left it as is, for now. Playing with the DPI...
Miked - 7/18/2017 7:13:41 PM
rikur - 7/18/2017 7:19:15 PM
rikur - 7/21/2017 8:15:47 AM
guille - 7/24/2017 2:11:42 PM
rikur - 7/28/2017 8:46:08 PM
rikur - 7/29/2017 11:13:28 AM
rikur - 7/29/2017 7:07:47 PM
rikur - 7/31/2017 7:41:48 PM
rikur - 7/31/2017 8:35:40 PM
                         That worked...! Don't understand why, though, but anyway. Thanks a lot...
rikur - 9/27/2017 3:43:18 PM
                 ‌I will do the step tonight ... wait & see.
SUBA - 10/28/2017 7:06:08 PM
rikur - 10/31/2017 1:07:58 PM
rikur - 10/31/2017 1:22:28 PM
rikur - 12/23/2017 6:51:35 PM
OmeRon - 1/2/2018 1:14:16 PM
rikur - 1/4/2018 10:27:21 PM
             Some suggestions in this thread:...
rikur - 2/21/2018 10:11:26 AM
                 Much appreciated! Working now. ‌ ‌ ‌
ADW666 - 2/21/2018 2:31:50 PM
rikur - 3/17/2018 8:41:50 PM
rikur - 5/25/2018 7:56:17 PM
rikur - 5/26/2018 11:49:59 AM
TJ - 6/30/2018 3:40:11 PM
rikur - 8/7/2018 7:11:36 PM
                 10.13.6
rikur - 8/12/2018 12:16:14 PM
rikur - 8/12/2018 12:28:48 PM
rikur - 8/20/2018 7:30:04 AM
rikur - 8/20/2018 11:15:55 AM
rikur - 8/20/2018 11:43:32 AM
rikur - 8/21/2018 1:52:29 PM
jryam - 9/14/2018 11:06:12 AM
rikur - 9/20/2018 7:37:29 PM
jryam - 9/21/2018 11:04:25 AM
gratd - 9/20/2018 4:23:22 PM
rikur - 10/6/2018 6:38:02 PM
JWB - 12/20/2018 2:12:24 PM
rikur - 12/20/2018 2:40:19 PM
rikur - 3/1/2019 8:31:02 AM
rikur - 3/8/2019 8:27:22 AM
                         I wouldn't estimate that due to Apple Rumors, making ipad apps running...
rikur - 3/25/2019 9:31:40 AM
rk19 - 3/27/2019 3:15:59 PM
gratd - 4/2/2019 10:19:19 AM
guille - 4/3/2019 10:33:03 AM
guille - 4/8/2019 4:38:35 PM
gratd - 4/30/2019 8:26:26 AM
rikur - 5/10/2019 8:33:41 AM
                         Fine! Same, as said, for näme. Really NO troubles at all. Even the...
                 Good news ! Thank you for the feedback :-)
fzahn - 5/18/2019 10:08:57 AM
gratd - 6/9/2019 12:23:11 PM
             Yes.
                 Huge Thanks - downloaded and worked first time.
gratd - 10/8/2019 9:41:30 AM
rk19 - 12/22/2019 2:38:56 PM
TJ - 3/3/2020 10:45:33 AM
Gourls - 1/31/2020 2:11:33 PM
arne - 3/29/2020 4:13:30 PM
TJ - 3/29/2020 9:38:37 PM
TJ - 3/30/2020 1:43:16 PM
MOIN - 7/28/2020 7:59:06 AM
