patrick_CH
Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)Forum Member (44 reputation)
Posts: 3, Visits: 0
With a version I received from Peter it works with Mojave now as well.
gratd
g
Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)Too Much Forum (80 reputation)
Posts: 6, Visits: 4
Just installed Mac OS Catalina. The wineskin doesn't work anymore. Is there a workaround for this?
peter.kesten
peter.kesten
Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)Too Much Forum (329 reputation)
Posts: 18, Visits: 14
gratd - 10/8/2019 9:41:30 AM
Did you try it instead of the old wineskin version with the winebottler version of which we are talking about all the time here lately? Or - even better - have you ever tried to compile your own winebottler package under Catalina, as described here in this thread (should be done the same way as in High Sierra)
I can not say anything about Catalina because I stayed at High Sierra on my Macs for many good reasons. SD is running reliably. And obviously also on Mojave. But as I said, on from high Sierra my support unfortunately has to end indefinitely.
Regards, Peter
gratd
g
Posts: 6, Visits: 4
A web search revealed that it has to do with the initiation file of the wineskin application running in 32bit. Catalina is 64bit. Solutions are being developed but not ready yet.
russellp
r
Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)Too Much Forum (141 reputation)
Posts: 14, Visits: 17
Seems like the latest update to Skydemon broke it on a mac - I'm just getting this now
Jeroen Ooms
J
Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)
Posts: 2, Visits: 41
No luck installing/runnig it with MacOS 10.15 :-(
rk19
rk19
Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)Too Much Forum (306 reputation)
Posts: 4, Visits: 108
SkyDemon now working with Crossover 19.0 on OS X 10.15.2 (Catalina).
Windows 10 bottle. Need to install Microsoft.Net 4.7.2 from within program and then install Skydemon (give permission in OS X system pref Security to allow apps downloaded from identified developers)
Gourls
G
Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)Too Much Forum (74 reputation)
Posts: 5, Visits: 1
I couldn't get it working at all with MacOS Catalina 10.15.2
I ended up using bootcamp and downloaded skydemon for windows and its working perfectly.
JBW1234
J
Posts: 1, Visits: 0
Hi Guys,
I have downloaded the latest update of Skydemon, and it seems that I now cannot get access to my waypoints. Keep getting the following message
I am running MacOS High Sierra.
Any suggestions?
Thanks.
Jon
Thomas Jensen
Thomas Jensen
Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)Too Much Forum (912 reputation)
Posts: 9, Visits: 11
rk19 - 12/22/2019 2:38:56 PM
Hi rk19,
Can you or someone else please confirm SkyDemon works with Crossover v19 and OSX version?? (I'm on Mojave)??
The Crossover product page is not an endorsement as it says "installs but won't run"
