LFR 95 Le Luc transit routes
acassata
acassata
Posts: 33, Visits: 277
Hello SD team,
SIA is one more time inconsistent regarding LFR95 Le Luc transit routes:
- VRP SA is duplicated in your chart. It is in Visual Approach Chart of Cuers Pierrefeu (LFTF) and of Le Luc Le Cannet (LFMC), but the description is slightly different. In fact, this VRP is not part of these airfields, is part of the transit routes of restricted area of Le Luc (LFR 95). This point is described in in France AIP ENR1.2-25 (page 22).
- VRP TV is duplicated in your chart. The reasons are the same as the previous point. The problem is that the position is not the same between the VACs. The coordinates in ENR1.2-25 seem the right ones and are confirmed by the last IGN chart for France Sud-Est.
Is it possible for you to report the problem of TV coordinates to SIA ?
Can you make anything to avoid duplicates and not associate them to any airfields ?
Alexandre
Based at LSGL (Lausanne - La Blécherette, in Switzerland)
Unfortunately because they are not in exactly the same position, we do not pick them up as being duplicates of each other.
I will forward this enquiry on to SIA but they have not responded to our previous two enquiries. Unfortunately it is common for them not to respond at all. They do not appear to like it when our users (and therefore we) attempt to explain that there is an error in their data.
acassata
acassata
The VRP SA is at the same position, only the description is slightly different. Is it possible to avoid the duplication in this case ?
Alexandre
You're right, it is. It's possible we could alter our code to detect this in the future and eliminate one of them (but which?) but in the meantime I would much rather the data was actually corrected by SIA, which I am hoping it will be.
