LFR 95 Le Luc transit routes
http://forums.skydemon.aero/Topic17565.aspx
By acassata - 11/14/2015 1:06:48 PM
Hello SD team,
SIA is one more time inconsistent regarding LFR95 Le Luc transit routes:
- VRP SA is duplicated in your chart. It is in Visual Approach Chart of Cuers Pierrefeu (LFTF) and of Le Luc Le Cannet (LFMC), but the description is slightly different. In fact, this VRP is not part of these airfields, is part of the transit routes of restricted area of Le Luc (LFR 95). This point is described in in France AIP ENR1.2-25 (page 22).
- VRP TV is duplicated in your chart. The reasons are the same as the previous point. The problem is that the position is not the same between the VACs. The coordinates in ENR1.2-25 seem the right ones and are confirmed by the last IGN chart for France Sud-Est.
Is it possible for you to report the problem of TV coordinates to SIA ?
Can you make anything to avoid duplicates and not associate them to any airfields ?
By Tim Dawson - 11/17/2015 11:17:11 AM
You're right, it is. It's possible we could alter our code to detect this in the future and eliminate one of them (but which?) but in the meantime I would much rather the data was actually corrected by SIA, which I am hoping it will be.
