"Loss of communication" warning
Posts: 368, Visits: 2.6K
Latest version Android running on a Samsung S4 Galaxy.
When flying I occasionally see this warning displayed. I understand the reason for the warning but wondered if the message box/pop-up could be reduced in size? At the moment the warning text is quite a long paragraph and the popup all but fills the entire screen obliterating the moving map.
I was wondering if the "Loss of Communications" warning could be in a similar theme and style like all the other warnings, such as "approaching CAS" etc. which are "overlaid on the moving map.
Tony Nowak
Can you be more specific about exactly which error message you are referring to? Perhaps a screenshot?
Here is a pic of the error I was reporting. This error message came up approx 5 times during a 1.5 hr flight.
You can see it, more or less, completely obscures the normal map display.
Tony
SD error.doc (648 views, 472.00 KB)
