Posts: 8.2K,
Visits: 9.8K
I've reproduced the issue with the charts window, not sure why it's happening with this hotfix build. Debugging it is proving challenging. In the meantime the best way of testing it for stability is to get your charts sorted with another version, then install the beta over the top of it like you did. If you ignore the charts window problem, how is it for stability?
