Visits: 19
I could use a little help here. I've installed the Compact Framework. I connected the 310 to the PC, and saw that active sync was working, and told SD to install SD Mobile. It appeared to work, although I got a message saying that it could not verify the presence of the Compact Framework. After the install finished, it started SD OK, so I presume that means that the CF is OK. On the first warning screen, it says to accept the VFR limitations, and I press Accept. It immediately goes back to the My Device page of the device. Any idea what's going on here? I assume something's missing, but have no idea what.
Thanks in advance,
Ed
