Exits when I press accept on startup screen
FlyingMonkey
FlyingMonkey
Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)Too Much Forum (334 reputation)
Posts: 4, Visits: 19
I could use a little help here. I've installed the Compact Framework. I connected the 310 to the PC, and saw that active sync was working, and told SD to install SD Mobile. It appeared to work, although I got a message saying that it could not verify the presence of the Compact Framework. After the install finished, it started SD OK, so I presume that means that the CF is OK. On the first warning screen, it says to accept the VFR limitations, and I press Accept. It immediately goes back to the My Device page of the device. Any idea what's going on here? I assume something's missing, but have no idea what.
Thanks in advance,
Ed
Posts: 8.2K, Visits: 9.6K
It's tough to say what might be wrong here, though I share your suspicion that it might be something missing. The trouble is, without any kind of error message, we can't tell what that might be. It seems like the software gets halfway through drawing the main screen (you see the SkyDemon button) but then fails.
