By FlyingMonkey - 10/28/2010 4:46:20 AM
I could use a little help here. I've installed the Compact Framework. I connected the 310 to the PC, and saw that active sync was working, and told SD to install SD Mobile. It appeared to work, although I got a message saying that it could not verify the presence of the Compact Framework. After the install finished, it started SD OK, so I presume that means that the CF is OK. On the first warning screen, it says to accept the VFR limitations, and I press Accept. It immediately goes back to the My Device page of the device. Any idea what's going on here? I assume something's missing, but have no idea what.
Thanks in advance,
Ed
By Tim Dawson - 10/28/2010 10:09:51 AM
Update: I think I might know what this is. I've made a little change that might help, and you'll see this in the next beta preview. Feel free to contact us directly if you'd like to obtain the hotfix build in the meantime, to see if it fixes your issue.
