MikeTwoOne
MikeTwoOne
posted 12/30/2013 6:53:00 PM
HOT
Visits: 2.1K
Sorry, not beta or suggestions related, but can't find a better place to post ...
Since version 3.0.3, I've had a lot (tens of) "silent crashes" when using SD on my 4.4.2 Nexus 7.
By "silent", I mean that the Android crash notification (the one which allows you to send a report) does not show. SD just
disappears
It happens when launching SD (mostly, sometimes 3 times in a row), when loading a route (sometimes) and when navigating too (real flight).
Unfortunately I can't find a way to clearly reproduce it. Note that
I never encountered that with the previous versions. Never.
I know that such a "bug report" does not really help without a log or a clear step to reproduce, so my question is about the correct way to report it.
Is there a way to really help identifying this issue?
A specific SD log I can find somewhere? Can a system log be helpfull?
Thanks,
M
Tags
3.0.3
android
crash
sweetpot
sweetpot
posted 5/5/2014 3:53:13 PM
Visits: 243
By "silent crash" I also mean a crash without pop up log report.
I confirm you that the 3.0.2 and 3.07 are crashing.
I'm using the 3.0.7 and I had a crash when closing the simulation mode this morning (+ the "normal" crashes when planning and flying).
Gregory.
MikeTwoOne
The only other similar issue we've heard of was because someone had...
1/9/2014 12:54:04 PM
Hi Tim, Thanks for your proposal. Unfortunately, a direct route from...
MikeTwoOne
1/22/2014 6:08:41 PM
"Since version 3.0.3, I've had a lot (tens of) "silent crashes" when...
funk
1/29/2014 10:22:31 AM
I'm having the same problem on 4.4.2. Whenever I scroll the map SD...
wb9999
2/8/2014 4:00:46 PM
I don't suppose any of you have the Android debugging tools installed...
2/10/2014 3:26:48 PM
Hi Tim, I have the last Android SDK on my main PC but even if I have...
MikeTwoOne
2/10/2014 5:16:59 PM
FYI, I've been able to connect to my Nexus 7 using ADB tools and I now...
MikeTwoOne
2/11/2014 2:17:24 PM
Yeah, logcat is definitely what you need to use. Android device...
2/11/2014 5:29:14 PM
OK. Using DDMS, I've been able to collect some lines of log. For...
MikeTwoOne
2/11/2014 9:37:32 PM
Thanks, that is helpful. We will get to work.
2/13/2014 11:21:04 AM
Hi, One more log, using a fresh 3.0.5 and opening a route. With a...
MikeTwoOne
2/26/2014 4:59:32 PM
Is this repeatable? Does it always happen when you load a route, or...
2/26/2014 5:30:19 PM
It happens with several different routes but does not happen everytime...
MikeTwoOne
2/27/2014 8:35:33 PM
Hello, I have a nexus 7 4.4.2 and I have the same problem with...
sweetpot
2/28/2014 8:47:15 PM
Any news on a fix for this issue? SkyDemon has been unusable on my...
wb9999
3/13/2014 5:57:23 PM
We will be posting a beta release next week which we hope will solve...
3/14/2014 3:59:51 PM
Hi, FYI, the last beta (3.0.6 - 04/01) is ... equally crashing, I'm...
MikeTwoOne
4/2/2014 12:26:06 PM
[quote] FYI, the last beta (3.0.6 - 04/01) is ... equally crashing,...
srayne
4/2/2014 12:54:43 PM
It definitely helps, in fact we can't do anything without the logs....
4/2/2014 5:07:55 PM
Here are the logs. Can you confirm the older versions of SD are...
MikeTwoOne
4/2/2014 7:27:03 PM
Thanks, these will help us.
4/3/2014 5:37:54 PM
Here is the 3.0.6 17809 delivery (one log only, because they are all...
MikeTwoOne
4/29/2014 2:52:40 PM
The logs quite definitely help. As before, I have forwarded this on to...
4/29/2014 4:56:05 PM
Do you by any chance have the ART runtime enabled on your device in...
4/29/2014 7:52:19 PM
After SD let me down in flight one more time two days ago, I was realy...
sweetpot
4/29/2014 8:13:59 PM
Hi, Not sure the questions are for me, since I've already reply them...
MikeTwoOne
4/30/2014 3:23:29 PM
Actually, we have been gradually escalating this issue ever since it...
4/30/2014 4:43:39 PM
I also have silent crashes, on Nexus 7 and SD 3.0.6.This seems to be a...
alberto
4/30/2014 7:37:13 PM
Has anyone tried the beta we released last night? If anybody wants to...
5/1/2014 10:54:45 AM
Hi, Thanks for the great feedback. Good to see I was wrong when...
MikeTwoOne
5/1/2014 12:08:40 PM
So it turns out we don't quite have the latest Xamarin.Android...
5/1/2014 5:23:52 PM
I just tried the 3.0.2 version. I got two silent crashes. The first...
sweetpot
5/2/2014 11:31:23 AM
After trying the 3.0.2 without success, I have just downloaded the...
sweetpot
5/2/2014 1:32:29 PM
I'm not quite sure what you mean by a silent crash. If you mean...
5/2/2014 3:33:13 PM
Hi, I also use "silent crash" to define the way SD is crashing...
MikeTwoOne
5/5/2014 7:55:28 AM
Hi folks I have now invested different SD versions 3.0.6, 3.0.7 and...
alberto
5/5/2014 3:01:24 PM
By "silent crash" I also mean a crash without pop up log report. I...
sweetpot
5/5/2014 3:53:13 PM
I'm not sure why you're not being offered the popup when it crashes, I...
5/6/2014 12:32:41 PM
I have some good news. We have managed to reproduce the occasional...
5/7/2014 3:06:31 PM
Hi Tim, That's great news! Knowing you're also reproducing the issue...
MikeTwoOne
5/7/2014 9:54:53 PM
Simulation mode doesn't work anymore with the may 7th beta & a silent...
Mike@EDTG
5/8/2014 6:58:14 AM
Simulation mode broken for me too.
srayne
5/8/2014 9:28:07 AM
Simulate mode is broken on purpose. We probably should have undone...
5/8/2014 9:47:18 AM
There will be a new beta later today. Results of tests over the...
5/12/2014 12:03:22 PM
Hi, Today's beta is definitely a big step forward. SD is way more...
MikeTwoOne
5/13/2014 8:38:05 AM
[quote][b]MikeTwoOne (13/05/2014)[/b]Hi,Today's beta is definitely a...
srayne
5/13/2014 8:46:55 AM
Hi, No root. I've installed the Android SDK, and, when connecting my...
MikeTwoOne
5/13/2014 11:20:24 AM
Thanks Mike for the info, I'll try that. Tim, I have been testing...
srayne
5/13/2014 4:08:00 PM
Hi, After some hours (around 7 ...) of testing since yesterday: - I...
MikeTwoOne
5/14/2014 1:50:47 PM
Thanks, that is good news. It seems we may have eliminated by far the...
5/13/2014 11:37:03 AM
I'll do some extensive testing this evening :)
MikeTwoOne
5/13/2014 2:26:59 PM
Hi, I didn't have a crash yet in the planning mode with the new beta,...
sweetpot
5/14/2014 5:27:48 PM
Does anybody know the features of the new beta (27.05.2014)?
alberto
5/27/2014 7:16:29 PM
There is only one Android feature change in the latest beta: You...
5/28/2014 10:14:42 AM
Latest android beta(27th May) seems to work well,......no cloning of...
Pete
6/1/2014 12:32:08 PM
Hi, I'm afraid crashs are back with 3.0.7.16856. Log is attached....
MikeTwoOne
6/3/2014 2:00:49 PM
No, that crash is different to the one which was causing stability...
6/3/2014 4:57:52 PM
[quote][b]Tim Dawson (03/06/2014)[/b][hr]No, that crash is different...
MikeTwoOne
6/5/2014 10:48:07 AM
Unfortunately, I got two crashes with the last beta. Both of them in...
sweetpot
6/4/2014 7:49:20 PM
I just upgraded to android 4.4.3, I will test tomorrow if it change...
sweetpot
6/5/2014 10:40:50 AM
Is it the same crash you are seeing?
6/5/2014 12:51:13 PM
The good news is that last crash you posted about is one we can catch...
6/5/2014 5:11:42 PM
At the moment I feel more comfortable using the official release 3.0.6...
alberto
6/5/2014 5:56:18 PM
Just bought a Hisense Sero 8 running Android KitKat 4.4.2 - a throw...
mickelb
6/6/2014 11:46:52 AM
I have tried the last beta with android 4.4.3 today. No more crashes...
sweetpot
6/6/2014 6:13:30 PM
mickelb, probably because the Google Play Store is not aware of the...
6/9/2014 10:59:50 AM
Tim - Hopefully Google will update their device list soon! At least...
mickelb
6/9/2014 1:22:27 PM
