Visits: 30
Hi, is there a document describing the use of the new collision detection feature? I have a "Butterfly Connect" connected to a TRX1500 which is PowerFlarm compatible and successfully shows traffic on the Butterfly external display.
But whenever I connect the iPad the Butterfly-WLAN (which seems to work) and go to "Setup" -> "PowerFlarm" -> "Flaying" I get a message box with:
"Lost connection to your GPS"
The "Butterfly Connect Key" is as printed on the "Butterfly Connect". On the second connection try I get "Failed to establish a connection with the Butterfly Connect unit."?
On the TRX1500 I can choose between different protocolls: "PowerFlarm Display" or "Garmin TIS" which one do I need?
