Butterfly Connect
http://forums.skydemon.aero/Topic10142.aspx
By hazlebury - 5/10/2017 10:45:36 AM
Hi - I am also fitting this but do you know if a bluetooth connection is possible?  My iPad will be connected to my wifi hotspot so I don't know how it would then also connect to the Butterfly Connect.
By Tim Dawson - 5/10/2017 11:11:44 AM
The Air Connect (as it is now known) works over Wifi. You need to connect to its Wifi hotspot to use it.
By hazlebury - 5/10/2017 11:46:49 AM
Thanks.  Do you have a screenshot anywhere that shows the traffic being display on SD on iPad?
By Tim Dawson - 5/11/2017 11:16:55 AM
Not to hand. There's one further up this page though.
By LutzRab - 8/23/2013 1:37:20 PM
Hi, is there a document describing the use of the new collision detection feature?
I have a "Butterfly Connect" connected to a TRX1500 which is PowerFlarm compatible
and successfully shows traffic on the Butterfly external display.
But whenever I connect the iPad the Butterfly-WLAN (which seems to work) and go
to "Setup" -> "PowerFlarm" -> "Flaying" I get a message box with:
"Lost connection to your GPS"
The "Butterfly Connect Key" is as printed on the "Butterfly Connect". On the second
connection try I get "Failed to establish a connection with the Butterfly Connect unit."?
On the TRX1500 I can choose between different protocolls: "PowerFlarm Display" or
"Garmin TIS" which one do I need?
