Integrated GPS Devices on Windows 8
mdovey
mdovey
Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)
Posts: 1, Visits: 12
It appears that integrated GPS devices on Windows 8 e.g. on Windows tablets are accessible via the Windows Location API and not via a Com port (this applies to Win 8 Pro as well as RT).
As such this means you can't use skydemon with such integrate GPS devices since this only works through com port access.
Are there any plans to support the Windows Location API.
Matthew
Not in the near future, I'm afraid.
Richardd55
Richardd55
Posts: 16, Visits: 1.8K
Centrafuse Localizer App seems to solve that issue.
Am on day 5 of 30 day free trial (£10 ish thereafter). Used it on 60NM flight ok
Might not be as good as Bluetooth GPS receiver but seems functional so far. Have put a review on Win App Store
makehela
makehela
Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)Too Much Forum (191 reputation)
Group: Awaiting Activation
Posts: 1, Visits: 9
Have you used any special settings or 'tricks'?
I get the localixer show the gps-data, but every time I'll start Skydemon's gps-tracking, SD crashes.
brgds, MH
gallwood
gallwood
Posts: 12, Visits: 47
Do you know if this is a windows 8.1 feature? I'm sure when I first tried SD on my win 8 tablet, it found the GPS hardware ok. Now in 8.1 it doesn't find it, because of what you have explained. Unfortunately I have just bought SD, never checked it with Windows 8.1.
Please can SD be updated to sort the new API?
gallwood
gallwood
makehela (06/12/2013)
brgds, MH
SD crashes for me too when using Localizer. Might have to buy a Bluetooth GPS device. Grrr.
gallwood
gallwood
Are there any kind of log files generated from SD which I could send to tech support in order to help diagnose the reason for the constant Crash when using the localizer app?
Thanks for your help.
There may be a debug.log file created in your SkyDemon folder (under My Documents) or error details might be in the window shown.
Richardd55
Richardd55
**** UPDATE ****
New Localizer version 4 and new licence file installed April 2014.
Generic Sat Nav software Memory Map and Skydemon now able to use inbuilt Broadcom GNSS in Win8.1 Asus Vivotab
Altitude and position reporting seems accurate enough with acceptable update interval. Start up reading of the datastream can be slow.
Installation frustrating. Must be installed and RUN as administrator or it crashes. This can be automated through Windows.
Once correctly installed and RUN as administrator, assigning a COM port (eg COM6) is easy.
If Localizer continues to work well I will give this 5 stars after testing in the air.
Original Post for Localizer v 3
To say that the failure of Microsoft to make provision for Existing Generic GPS software to access inbuilt GNSS under WIN8 is short sighted is an understatement.
Under win 8.0 the localizer software and SD (and another Sat nav Mapping application) worked well enough. Since upgrading to Win 8.1 I have had little luck getting the SD Navigation mode to run using Localizer (M Map still works ok)
Solutions seen to revolve around
SD writing the navigation element to address the Win Location platform instead of (or as well as) com ports and so removing the need for a product like Localizer
or Broadcomm/Asus producing an updated GNSS driver
or Centrafuze doing some reprogramming
People using generic marine software are having exactly the same issues. It's a mess that leaves us consumers very frustrated
I had some success using the Lenovo GNSS driver under win 8.1 but it wasn't perfect - often taking 5 to 10 mins to find satellites, so for the time being I've rolled back to the default GNSS driver and use this for M Map and a Bluetooth GPS receiver for SD
Richard
Edited 4/5/2014 9:07:35 AM by Richardd55
