Fonts size on High Resolution Screens
guille
guille
Posts: 149, Visits: 2.4K
Hi, yesterday I used the first time SD flying, Using a device with a high resolution screen, the fonts of menus and those on the window providing Nearby Air Traffic Services (extremely useful) appear quite small. Could it be possible to increase the fonts size, as it is the case for the map ?
Another suggestion: opening the log after flying there is a good synthesis of the flight. Could it be possible to save it in a standard format (txt, xls ...)
Thanks in advance for your answer
adhawkins
adhawkins
Posts: 274, Visits: 2.5K
What type of device is this?
If it's Windows based, you have to tell the device the size and resolution of your screen via an XML file. There's a utility somewhere on here where you enter those parameters, and it generates the file for you.
Andy
guille
guille
It is an Android device, Samsung GT 7.7 . I have installed SD also on my Samsung S2 smartphone, and in the small S2 the fonts are bigger than in the wonderful screen of the GT 7.7.
I tried with the file for the Windows OS and of course it does not work ...
It would be nice to be able to have bigger fonts in the GT 7.7
Thanks in advance,
Guillermo
There is a standard setting somewhere in your device that controls the size of fonts used by all apps on the device. There isn't another one in SkyDemon specifically for that reason. Hopefully you'll find it somewhere in the Settings bit.
Flight logs can be sent by email, which exports them in GPX format which can then be loaded into all sorts of third-party software.
guille
guille
Thanks for your post, but ... the size of fonts changes for a lot of applications, not for SD unfortunately ...
Just for information, it changes some windows only: for example one, when opening a route saying that the definition of cruise profiles do not match... but the windows with information about frequencies, the menus, etc. remain always with the same size of fonts.
Guillermo
Edited 5/24/2013 4:24:04 PM by guille
