Fonts size on High Resolution Screens
http://forums.skydemon.aero/Topic9380.aspx
By guille - 5/24/2013 9:13:01 AM
Hi, yesterday I used the first time SD flying, Using a device with a high resolution screen, the fonts of menus and those on the window providing Nearby Air Traffic Services (extremely useful) appear quite small. Could it be possible to increase the fonts size, as it is the case for the map ?
Another suggestion: opening the log after flying there is a good synthesis of the flight. Could it be possible to save it in a standard format (txt, xls ...)
Thanks in advance for your answer
Guillermo
By guille - 5/24/2013 4:10:51 PM
Thanks for your post, but ... the size of fonts changes for a lot of applications, not for SD unfortunately ...
Just for information, it changes some windows only: for example one, when opening a route saying that the definition of cruise profiles do not match... but the windows with information about frequencies, the menus, etc. remain always with the same size of fonts.
Guillermo
