Bug in Woindows 8 64 bit
mooro1973
mooro1973
Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)Too Much Forum (177 reputation)
Posts: 2, Visits: 3
I can't use skydemon on WIndows 8. Keep getting "unhandled exception errors":
System.InvalidOperationException: The specified window is not open.
at TD.SandDock.DockControl.OpenWith(DockControl existingWindow)
at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.6400 (Win8RTMGDR.050727-6400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
I have tried un and reinstalling sky demon.
Edited 4/28/2013 9:23:57 AM by mooro1973
mooro1973
mooro1973
Posts: 2, Visits: 3
Apologies for typo in title.
Can you contact us through email so that we can help you with this please? There is a Contact Us page on our website.
duncans
duncans
Posts: 13, Visits: 30
Mooro1974,
Did you get this fixed? I am experiencing the same (similar) fault in my Windows7 machine.
Not much joy from tech support at the moment other than install latest, reboot etc.
D
I think we have solved this, ready for the next update.
