Bug in Woindows 8 64 bit
http://forums.skydemon.aero/Topic9074.aspx
By mooro1973 - 4/28/2013 9:23:43 AM
I can't use skydemon on WIndows 8. Keep getting "unhandled exception errors":
System.InvalidOperationException: The specified window is not open.
at TD.SandDock.DockControl.OpenWith(DockControl existingWindow)
at Divelements.SkyDemon.x210ff09a2516b1a7.x80c5917e13d6bc71(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.6400 (Win8RTMGDR.050727-6400)
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
I have tried un and reinstalling sky demon.
By Tim Dawson - 6/6/2013 12:49:06 PM
I think we have solved this, ready for the next update.
