SD installation on external SD card on Android
milansmid
milansmid
Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)
Posts: 68, Visits: 565
Hello SkyDemon,
Where is the SkyDemon installed by default on Android devices?
To me it appears that it is installed on the device's internal SD card (I suppose because when I removed my external SD card it was still happily running :-))
Could you please make it optional to install (at least the charts) on the external SD card? The reason for this is that the internal SD card capacity is pretty limited and SkyDemon takes a fair bit Smile
Thanks for consideration.
Regards,
Milan
Edited 4/26/2013 1:16:03 PM by milansmid
You should be able to move SkyDemon to your SD card from the Apps settings on your Android device, if your device supports such things.
OldDogNew
OldDogNew
Posts: 17, Visits: 245
I have just installed a microsd card in my Samsung Galaxy S4, and successfully moved SD onto it. However the data (charts, plates etc) still seem to be stored on the internal storage. Does anyone if/how it is possible to move these files onto the microsd card also? I know how to move them manually, but presume that if I did that SD would not be able to find them afterwards. Thanks.
ajmc
ajmc
Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)Too Much Forum (723 reputation)
Posts: 5, Visits: 13
OldDogNew - 2/8/2014 6:52:48 PM
I know that this is an old post, but at the moment the maps, and I assume other cached data, on the main storage of my Android device is 455MB!  I have the application on my external SD card, but cant find a way to move the maps/aircraft/routes etc to it.
The internal storage is not that big, so saving 455 MB would make the world of difference.
So is there any way to move all of the maps etc to the external SD card as well as the application its self?
Not that I know of.
