SkyDemon Mobile Beta 1.3.3
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Tim, I've been holding off to see if anyone else had a problem with the Trajectory Display Menu. (Obviously notBigGrin)
On the previous full version & the last 2 betas, I've been unable to change "Settings" - "Preferences" - "Moving Map"  Trajectory Display. When I click the arrow, the box turns blue, but no other option shows. I can only change by opening settings.xml, & editing <AircraftDisplayOptions TrajectoryDisplay=  with notepad. The new value is then recognised.
(Still not able to bring up Notams on the Satnav either.
Using  WinCE5 &  WinCE6 4.3" Satnav units.
Everything else works beautifully. Program is getting to the stage where, if I wasn't so tight fisted, I'd buy it.
Regards,
Max.
This is likely to be one of those annoying device-specific issues, my only guess is that it might be because that box stretches across the whole screen. We'll try reducing its size a bit for the next beta drop.
SkyDemon Mobile will only neglect to load NOTAM if it perceives the briefing to be too out of date to show (> 24 hours). Sure the date and time are set right on there?
If you've no intention of purchasing SkyDemon one might almost suggest there's not much point in posting on here. Not that we don't like feedback...
Max_UK
Max_UK
Thank you Tim,
The latest Beta 1.3.3  (Updated 12 August 2010) has fixed the Trajectory Menu problem & I can also access the Notams.
Used the prog today, ( first time as a "Fully Licensed" user)  for a trip from Shoreham to White Waltham & back. It behaved perfectly.
Regards,
Max.
