Tim, I've been holding off to see if anyone else had a problem with the Trajectory Display Menu. (Obviously not
)On the previous full version & the last 2 betas, I've been unable to change "Settings" - "Preferences" - "Moving Map" Trajectory Display. When I click the arrow, the box turns blue, but no other option shows. I can only change by opening settings.xml, & editing <AircraftDisplayOptions TrajectoryDisplay= with notepad. The new value is then recognised.
(Still not able to bring up Notams on the Satnav either.
Using WinCE5 & WinCE6 4.3" Satnav units.
Everything else works beautifully. Program is getting to the stage where, if I wasn't so tight fisted, I'd buy it.
Regards,
Max.
