How to work with Proxies
Rob Swain
Rob Swain
Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)Too Much Forum (896 reputation)
Posts: 8, Visits: 70
Telling SkyDemon explicitly about a specific proxy gateway is often necessary on large corporate networks, even with (especially with?) windoze 7 which can be too clever for its own good.
Setup > Planning Options from the menu bar in SD.
Misc tab.
Proxy Server Options button.
You'll have to work out what goes in the boxes for yourselves, as it will depend on the corporate network involved.
Just have to remember to change your password in the SkyDemon settings when you change your system password. Ask me how I know this...
I know this question has been answered, but thought I'd post the explicit answer as a reminder to myself for later!
Tags
Edited 7/28/2014 2:27:48 PM by Rob Swain
riverrock
riverrock
Posts: 8, Visits: 20
Fair enough Tim - thanks!
I can't offer anything more insightful than a suggestion to check the proxy settings in the SkyDemon options, I'm afraid.
riverrock
riverrock
Same issue as OP I suspect. Hope it is OK to resurrect the old topic!
Proxy settings are "auto-detect" within Win7. All browsers work fine with nothing special set.
There is a proxy in place, and I know from experience that a small number of websites are blocked, although that doesn't include any SkyDemon websites.
I have at least one other program that requires me to put in a proxy username / password to allow the program to continue.
Any way to tell whether it is a network blocking issue rather than a proxy authentication issue?
Oh - and I tried adding the proxy details into setup / Planning / Misc / Proxy Options but it made no difference.
http://i.imgur.com/yZyjtvP.png
Tags
Edited 3/17/2014 11:30:06 AM by riverrock
Posts: 593, Visits: 4.9K
rosdol (11/05/2013)
why did you not mention this before. I will go and try this on my Office machine first thing on Monday
Because in your earlier post, you said your proxy server settings were empty when you looked in the browser settings and that you didn't know your proxy server address!
I really can't see it making much difference because SD will use your system-wide proxy settings which are obviously working OK as your browser is fine.
rosdol
rosdol
Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)
Posts: 48, Visits: 215
Thanks Steve,
I try this out first think on Monday in the Office !
br
Erik
rosdol
rosdol
Hi Steve,
thanks
Erik
I did not misunderstand, and was not assuming you were using SD in a browser.
SkyDemon by default uses your system proxy settings. So, whatever is set as the proxy for your system (in the location I gave you before), SkyDemon will use.
If you can access the internet using Internet Explorer on your machine, then SkyDemon should work. If it doesn't, then there's a problem with the configuration of the proxy server. It would be worth asking your IT department to investigate.
If you need to set an explicit proxy server, it can be set under Setup > Planning Options > Misc, but it should not be necessary.
Steve
rosdol
rosdol
the SD Folks obviously think, that I am using SD from the browser - which I am not. I am using it the same way you do it - directly from the SD application. However - due to lack of a qualified answer from SD - I would assume you cannot change the Proxy Settings in the SD application, hence you Need to use the browser app !1
br
Erik
Sussex Flyer
Sussex Flyer
Posts: 22, Visits: 95
On my Company network our IT geeks have put in something place to prevent access to certain internet sites, although I can access most non risky websites and SD loads and runs fine, I do get the proxy 407 message if SD wants to update a chart, get Notams or update the weather.
In the LAN connections page the "use a proxy server" option is ticked but the only information obviously available is port set to 80.
Now, I'm not too worried about Notams and weather while at work as the lunchtime route planning exercise can be fine tuned at home later, but it would be useful to manually update the charts via download, is that possible?
Failing that, is there a way of finding the proxy settings without bothering our overworked IT gurus?
Sussex Flyer
