Kaliningrad under water
Flying Tiger
Flying Tiger
Posts: 24, Visits: 77
I noticed that when I install the Latvia, Lithuania, Estonia maps (on my PC) the Kaliningrad area on the base-map disappears, or actually turns into water. When I un-install the maps, the Kaliningrad area returns. If you zoom out on the map as far as possible, you can see the Kaliningrad area, but when you zoom in and you come to the point when the FIR boundaries start to appear on the map, then the Kaliningrad area disappears. If you continue to zoom in, you will just see roads and rivers in the sea, and it looks like the whole country is under water.
I also noticed that there are no visual reporting points, nor georeferenced plates for the Baltic countries.
Posts: 8.2K, Visits: 9.6K
Thanks, we will add Kaliningrad high resolution outline in the next chart update.
I do not believe VRPs are currently in the included data list for the Baltic countries. If these are published in the AIP we may include them in a future chart update. Do you know if this is the case?
Flying Tiger
Flying Tiger
OK, thanks for the map-information Tim!
Yes, the VRP:s for the Baltic countries can be found in the national AIP:s. The VRP:s, including their co-ordinates, also already appear on the visual approach charts in SKyDemon, but not on the base-map.
