Charts and Aeronautical Data
Med crossings
Med crossings
Med crossings
daniel verreyken
d
daniel verreyken
posted 8/1/2016 1:46:51 PM
d
Visits: 0
Hello Tim,
Thank you for the reply.
Switching on the "airways reporting points" solves the problem.
I thought these were "vfr reporting points".
Regards,
Daniel.
posted 8/1/2016 9:17:22 AM
Posts: 8.1K,
Visits: 9.3K
Which reporting points do you believe are missing? Have you checked your map layer settings?
daniel verreyken
d
daniel verreyken
posted 7/31/2016 5:01:44 PM
d
Visits: 0
the VFR routes over the Western Mediterranean Sea are on the map, however most of the names of the reporting points are missing.
Regards,
Daniel
posted 3/22/2013 11:08:49 AM
Posts: 8.1K,
Visits: 9.3K
Hello Seb, thanks for the feedback, this is something we are looking at adding for the next AIRAC cycle.
Basoutos
Basoutos
posted 3/21/2013 9:06:41 PM
Visits: 2
Thanks for the very good work.
One thing that is missing from your chart is the mandatory VFR routes and reporting points in the med. For example, to go to Corsica from Cuers, one has to fly through a point called MERLU (which is in your database of IFR waypoints). This is typically shown on all paper maps for france. Full data is in the AIP:
https://www.sia.aviation-civile.gouv.fr/aip/enligne/PDF_AIPparSSection/AIP%20FRANCE/ENR/1/1304_ENR-1.2.pdf
General Air Traffic aircrafts are authorized to fly over the western mediterranean under VFR rules when following the routes and in compliance with the
procedures stated below...." see pages 10 and 10a.
It would be great if you could add the mandatory routes as lines and the reporting points as VRPs.
Seb
