Disappearing airfield waypoints
2high2fastagain
2high2fastagain
Posts: 43, Visits: 98
Is there any reason why the runways of some airfield disappear as you zoom out, while others remain? It's a bit irritating when planning long journeys because you can't select the airfield as a starting waypoint at the desired levels of zoom (1:560,000 in my case). All you see is a coloured circle which denotes the ATZ. Airfields affected include Netherthorpe, Wickenby, Clacton and Derby on my copy of Skydemon (2.4.2.16291)
As you zoom out, features are removed to keep the maps clear. Airfields with shorter runways are removed first.
2high2fastagain
2high2fastagain
I thought that might be the case, but it does Introduce a problem. It isn't possible to select those airfields as departure points when they are zoomed out even though they are licensed aerodromes at any scale smaller than half mill as far as I can see. It's mildly irritating seeing microlight strips still on the map at those scales. You leave the ATZ in place at small scales so it would be nice to leave a circle in the middle so we can plan from these airfields.
Posts: 593, Visits: 4.9K
Can't you just zoom in a bit to choose the airfield? Would you rather one airfield's label obscured another - which would be the only other way.
Alternatively, use the Route > Create Route option - it's quite a bit quicker than scrolling around the map anyway.
2high2fastagain
2high2fastagain
I'm not complaining about the concept of decluttering, but about the application of it.
It looks like the threshold is set so that licensed aerodromes with maximum runway length of less than 600m disappear at zoom levels of 1:545,000, although their ATZs don't disappear until 1:2,140,000. Microlight strips that are longer than 600m (e.g. Knockin at 650m) remain on the map until zoom levels of 1:1,000,000. Interestingly VRPs seem to disappear at 1:800,000, while the little used long farm strips of 601m or longer are still there.
If you take Clacton, the airfield disappears and becomes unclickable at the half mill point, while Clacton town's label doesn't disappear and become unclickable until about 1:750,000. I know which is more useful to me when I'm planning. When I did select the middle of Clacton's ATZ at those scales, then I was rewarded with a Lat/Lon waypoint.
I suggest that either licensed aerodromes remain clickable until 1 to a million or the declutter threshold be reset from 600m to 530m (which I think will encompass all the licensed fields). At small scales, I think it's most useful to know where airfields and airspace (inc danger areas) are, rather than town names etc.
The reason ATZs remain for longer is that they're airspace, and the threshold for airspace is quite high. The suggestions you have made would work very well in the UK, but we have a much larger area to consider than just the UK and whatever we do has to make as much as sense as possible throughout the whole area, where data such as whether an airfield is licensed or not is not always as available as we'd like.
I do disagree with the notion that a licensed airfield with short runways is any less important than an unlicensed airfield with long runways, which may even have superior facilities to the licensed one. This is something everyone has different opinion on, I know.
One piece of information we could add to our threshold logic would be whether an airfield has an ICAO designator. Those are, in general, likely to be either licensed or to have a decent level of facilities. I will have a play with this later on...
2high2fastagain
2high2fastagain
The ICAO designator is a neat idea.
Let's agree to disagree on licensed aerodromes. If I had an engine failure and I could glide to a licensed or unlicensed strip I know which I'd go for. The one with a surface I could trust and fire cover, even if it was a bit shorter. In that respect the new starfish in the beta are pretty helpful, though it will take a little time I suspect before everyone feels comfortable with them.
Surely if you had an engine failure, the very last thing you'd be doing is fiddling around with your GPS.
If you did decide that GPS fiddling was the order of the day, I'd suggest that the Direct To function would be far more useful than scrolling around the chart.
