PC Synce to Garmin 695 and or SD card problems
mikeg
mikeg
Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)Too Much Forum (1,000 reputation)
Posts: 5, Visits: 21
hope this is an easy one..i wanted to sync a trip through the USB lead onto the 695, each time i did it skydemon stopped responding.
so i tried saving the trip onto an SD card, i saved it in all 3 formats but when i installed the card into the 695 none of the files were visable.
anyone got any ideas
thanks
Might be worth updating your Garmin drivers if exporting via USB is causing a machine lockup.
mikeg
mikeg
Hi Tim
sorry for the sorry for the late reply...just got back from holiday !
ok, i have done the following and it still wont work
  1. updated USB driver
  2. uninstalled sky demon and re installed
  3. uninstalled and reinstalled latest beta version of sky demon
  4. installed onto another PC
  5. check i have latest garmin firmware
  6. installed Garmin Trip and Waypoint manager
the Garmin works fine with the garmin trip / waypoint manager, so as a stop gap i can save the sky demon file as a garmin file, open it up in the garmin software, and then upload ok - not ideal !
i have spoken to garmin, they are going to download sky demon to see if they have the issue...
my mate did have an issue and once he had uploaded the new driver it was ok.
when i select the uplaod from sky demon, it going into a "processing mode" ...i leace it for 5 mins and nothing happens, then i get a "not responding" and have to close down...
do you have any more ideas?
thanks
mike
mikeg
mikeg
Good News !!!!
All sorted, the problem was a currupt floght log on the 695. i deleted about 10 saved files and it effectivly cleared the blockage !
now works a treat !
thanks
mike
