Europe map data problem
trukkakhan
trukkakhan
Posts: 29, Visits: 57
Hi folks,
I added France and Benelux data recently to the data folder along with UK and Ireland.
When I panned out only UK and Ireland were visible - blue everywhere else.
I did use ActiveSync to move the files ( as I did with all the other files) - then I downloaded the latest versions of map data and moved them over via ActiveSync - still lots of blue and no France or BeNeLux.
Any idea what I am doing wrong ? The rest works fine.
If you're not seeing any errors in the messages window (Tools -> Messages) then the charts are loading ok, but might just be a long way offscreen. Try using Chart -> Find Waypoint to force the map to move to a waypoint in the new countries.
trukkakhan
trukkakhan
Under "tools" on the menu bar I do not have the "messages" option.
Also under Chart/Find waypoint I can only find UK and Ireland waypoints. Typing in LFAC for example kept the OK button greyed out and no info in the panel underneath.
If you don't have the option to show messages under the tools menu, you'll want to upgrade to a later version. This will either solve the bug you're running into or make that command available, which should tell you why the chart isn't being loaded.
