Europe map data problem
trukkakhan
trukkakhan
Posts: 29, Visits: 57
Hi folks,
I added France and Benelux data recently to the data folder along with UK and Ireland.
When I panned out only UK and Ireland were visible - blue everywhere else.
I did use ActiveSync to move the files ( as I did with all the other files) - then I downloaded the latest versions of map data and moved them over via ActiveSync - still lots of blue and no France or BeNeLux.
Any idea what I am doing wrong ? The rest works fine.
If you don't have the option to show messages under the tools menu, you'll want to upgrade to a later version. This will either solve the bug you're running into or make that command available, which should tell you why the chart isn't being loaded.
