New Version 2.3 defaults to rotated screen on MD device
Norf99
Norf99
Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)Too Much Forum (359 reputation)
Posts: 4, Visits: 255
I've just installed the new version 2.3 on my Laptop and Skydemon MD device. When I start the MD device it always rotates the screen into portrait mode on startup - even if I shut it down in Landscape. Is there a setting somewhere I'm missing?
Thanks, Ian
BAT-21
BAT-21
Posts: 4, Visits: 71
Hi Ian
Had the same problem after I upgraded.
If you go Settings & select Rotate Screen everything returns to landscape mode. This then appears to be the default when restarting the system
Norf99
Norf99
So that's behaviour that's changed from the previous release. Tim - any specific reasoning behind that?
No specific reasoning, it's clearly a bug. Rotating the screen back again should solve it.
Flybynight
Flybynight
Posts: 14, Visits: 90
Interesting! My unit says its rotating (which it never did before) and then comes up in landscape mode. Which was its default mode before anyway.
srayne
srayne
Posts: 388, Visits: 8.3K
Flybynight (13/03/2012)
My WinCE device does this as well even though it does not support screen rotation.
Norf99
Norf99
My problem was that I although I could get it to rotate back to "normal" I couldn't seem to change the default setting back to that. I found that by rotating it back, then System > Exit before turning the power off sorted it out.
