SkyDemon Navigation
New Version 2.3 defaults to rotated screen on MD device
Norf99
Norf99
posted 3/9/2012 9:30:57 PM
Visits: 255
I've just installed the new version 2.3 on my Laptop and Skydemon MD device. When I start the MD device it always rotates the screen into portrait mode on startup - even if I shut it down in Landscape. Is there a setting somewhere I'm missing?
Thanks, Ian
BAT-21
BAT-21
posted 3/10/2012 3:52:36 PM
Visits: 71
Hi Ian
Had the same problem after I upgraded.
If you go Settings & select Rotate Screen everything returns to landscape mode. This then appears to be the default when restarting the system
Norf99
Norf99
posted 3/11/2012 7:12:28 PM
Visits: 255
So that's behaviour that's changed from the previous release. Tim - any specific reasoning behind that?
posted 3/13/2012 4:22:34 PM
Posts: 8.3K,
Visits: 9.8K
No specific reasoning, it's clearly a bug. Rotating the screen back again should solve it.
Flybynight
Flybynight
posted 3/13/2012 5:56:09 PM
Visits: 90
Interesting! My unit says its rotating (which it never did before) and then comes up in landscape mode. Which was its default mode before anyway.
srayne
srayne
posted 3/13/2012 6:12:10 PM
Visits: 8.3K
Flybynight (13/03/2012)
My WinCE device does this as well even though it does not support screen rotation.
Norf99
Norf99
posted 3/15/2012 10:55:58 PM
Visits: 255
My problem was that I although I could get it to rotate back to "normal" I couldn't seem to change the default setting back to that. I found that by rotating it back, then System > Exit before turning the power off sorted it out.
