OBS hold mode
tmmorris
tmmorris
Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)
Posts: 2, Visits: 6
Does Skydemon mobile (MD or otherwise) provide an OBS hold feature, a la Garmin Aera/196?
My trust Lowrance Airmap 1000 has died (and anyway the database updates have dried up) so I am hoping Father Christmas will oblige with a new GPS. I need to know what to put on my list... and the Skydemon looks great (I've downloaded the demo version). But I use the Lowrance to 'monitor' NDB approaches setting the active waypoint to the NDB and the OBS to the outbound/inbound track (great for holds, too as it makes every NDB basically a VOR/DME...)
I can't find a way to do this. If it's not there, can it be added, please..?
Tim
Admin
Admin
Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)Too Much Forum (6K reputation)
Group: Administrators
Posts: 48, Visits: 212
I don't even know what an "OBS hold" is, could you explain how it works?
tmmorris
tmmorris
Posts: 2, Visits: 6
Works like a VOR receiver. You can select the inbound or outbound course to/from the waypoint, and guidance is provided relative to that radial, rather than to the flightplanned course between waypoints.
Tim
Posts: 8.2K, Visits: 9.5K
I see, thanks. This is certainly something we'd consider adding though it seems more suited for IFR-style flying. I'll be interested to see what other people think of the idea.
mark40
mark40
Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)Too Much Forum (298 reputation)
Posts: 2, Visits: 21
Thank you
Good post
mark40 mark
Brianh
Brianh
Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)Too Much Forum (274 reputation)
Posts: 2, Visits: 6
I was taught to use Obs hold for creating a run in line to a DZ waypoint when para dropping. Makes life really easy and a "must have" for me even though a VFR activity. Good tip re the NDB too! Otherwise Skydemon looks really good for my impending GPS replacement; I already use the "light" version for UK VFR planning.
Runways
Runways
Posts: 309, Visits: 1.6K
Actually a very nice idea. My motto is: Good for IFR=Good for VFR.
IFR is simply the GUI of VFR.
PS: GUI= Graphic User Interface (For those who need help only!)
Very Newbytheway
DurhamTeaseAirport
Edited 5/11/2013 6:53:55 PM by Runways
C401
C401
Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)Too Much Forum (749 reputation)
Posts: 14, Visits: 84
Found this thread while searching to see if it was already available and I just didnt know how to use it.
I would find this feature very useful.
mallyrich
mallyrich
Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)Too Much Forum (401 reputation)
Group: Awaiting Activation
Posts: 4, Visits: 27
I would like to see this feature too. Is there somehow we could campaign for it?
The OBS feature is useful not just for IFR work.
As a previous post explains. You can project a continuous radial line, through a chosen waypoint.
You simply require:
Waypoint
Radial, in degrees, From
The continuous line intersects the waypoint in the chosen direction, and can then be tracked 'TO' or 'FROM'
It is similar to a runway extended centre line feature.
Sometimes requested in controlled airspace, 'on reaching beacon, fly a track of 060'
Useful for approaching a waypoint in a certain direction
Frequently required for para dropping.
I have read posts in Forums where customers have gone with other systems as SD does not currently support this.
Would really like this feature.
Mally
Could you point to one of those posts, please?
You can create relative waypoints in SkyDemon, so you could create a waypoint on a radial from any other waypoint, and then plan a route along that radial. The HSI instrument (in fact all instruments) would then guide your flight along that leg following the radial.
