Running Inflight with FSX?
flyer73
flyer73
Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)Too Much Forum (75 reputation)
Posts: 1, Visits: 1
Hi all, wondering if anyone can help.
Been trying to download the software to run sky demon in flight simulator x, however I cannot run the installation program FSX2NMEA, advises me that I have to changed the GCA(global assembly cache).
Appears - Microsoft Flight Simulator.SimConnect Version10.0.61259.0 be installed in the Global Assembly Cache(GAC) first.
Not computer literate and was wondering if you could help.
Best Regards.
Flyer73
TheDaniel
TheDaniel
Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)Too Much Forum (319 reputation)
Posts: 3, Visits: 8
col-lucy (30/08/2011)
Hi all,Yes, I am pretty certain the problem is with the Virtual Serial port setup. The port numbers sound wrong. Fsx2NMEA is connected to a TCP socket, but the data must be getting lost at the serial port. I have put a document on my Skydrive with screenshots that show all the serial port settings of Fsx2NMEA, HW Virtual Serial Port & Skydemon Plan. If necessary, delete your serial port config & set up again.
https://skydrive.live.com/?cid=062a857fb93775aa#cid=062A857FB93775AA&id=62A857FB93775AA%211701
Hope that works.
Hi, would it be possible to make that file available again? Skydrive tells me its gone (and it's been a while since that post)
Thanks,
Daniel
Edited 2/2/2014 7:30:33 PM by TheDaniel
