Quarantine aircraft or client from producing logs
Eseem
E
Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)Too Much Forum (55 reputation)
Posts: 6, Visits: 53
While I'm a huge fan of the logs in general, I also use SD with flightsim some times or even in the window seat in an airliner if I want to figure out what I'm looking at, and those logs are not very useful at all. Obviously I forget to delete them and they just sort of blend into the pile of actual flight logs, so I was thinking it would be incredibly useful if an aircraft profile (or even my entire desktop PC client) could have an option to not produce a log when flying, a "not PIC" option if you will.
Boeingboy
Boeingboy
Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)Too Much Forum (867 reputation)
Posts: 61, Visits: 748
I use SD with my flight sims and just delete the log at the end of the session.
Eseem
E
Boeingboy - 11/1/2026 9:33:34 AM
That would be the smart thing to do. Alas...
SkyDemon logs have a Simulated flag which should be set if you use SkyDemon with a flight simulator.
There isn't an option to stop SkyDemon from making a log at all, but on your PC, is it a problem if simulated logs build up? You're presumably not using them for anything.
