Quarantine aircraft or client from producing logs
http://forums.skydemon.aero/Topic39176.aspx
By Eseem - 10/31/2026 9:53:11 PM
While I'm a huge fan of the logs in general, I also use SD with flightsim some times or even in the window seat in an airliner if I want to figure out what I'm looking at, and those logs are not very useful at all. Obviously I forget to delete them and they just sort of blend into the pile of actual flight logs, so I was thinking it would be incredibly useful if an aircraft profile (or even my entire desktop PC client) could have an option to not produce a log when flying, a "not PIC" option if you will.
By Tim Dawson - 11/2/2026 10:50:29 AM
SkyDemon logs have a Simulated flag which should be set if you use SkyDemon with a flight simulator.
There isn't an option to stop SkyDemon from making a log at all, but on your PC, is it a problem if simulated logs build up? You're presumably not using them for anything.
