Importing KML file into Skydemon
Simco
S
Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)Forum Newbie (2 reputation)
Posts: 1, Visits: 0
I have just been on a multi-leg trip around Europe and wanted to display this all on my Skydemon in the normal tracklog form.
However because the flights were greater than 10 minutes apart I was unable to do this.
I imported all of my tracklog files into Google earth and used a converter tool which has put them all into 1 KML file which works beautifully. Id like to display this on the Skydemon map however and have been trying to use the "open from different location or with different filetype feature" to display that merged track.
It didn't recognise the KML files, so I converted those to GPX, which it did but then I had an error string as I tried to load it...
Any Ideas would be greatly appreciated!
System.NullReferenceException: Object reference not set to an instance of an object.
 at Divelements.SkyDemon.IO.GarminMagellanExporter.GetGpxTrackSnapshot(XmlNode trkptNode, DateTime& startTime)
 at Divelements.SkyDemon.IO.GarminMagellanExporter.GetFlightLogsFromGpx(XmlDocument d, WaypointManager waypointManager)
 at Divelements.SkyDemon.frmMain.menuToolsOpenFlightLog_Activate(Object sender, EventArgs e)
 at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
 at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
 at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
 at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
 at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
 at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
 at System.Windows.Forms.Control.WndProc(Message& m)
 at System.Windows.Forms.ToolStrip.WndProc(Message& m)
 at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
  Assembly Version: 4.0.0.0
  Win32 Version: 4.8.9310.0 built by: NET481REL1LAST_C
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SkyDemon
  Assembly Version: 4.1.2.21099
  Win32 Version:
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
Divelements.Aviation
  Win32 Version: 4.1.2.0
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
  Win32 Version: 4.8.9256.0 built by: NET481REL1LAST_B
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
  Win32 Version: 4.8.9032.0 built by: NET481REL1
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.Web.WebView2.Core
  Assembly Version: 1.0.1518.46
  Win32 Version: 1.0.1518.46
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Microsoft.Web.WebView2.Core.DLL
SandDock
  Assembly Version: 3.0.6.1
  Win32 Version: 3.0.6.1
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
  Assembly Version: 3.0.179.0
  Win32 Version: 3.0.179.0
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
  Win32 Version: 4.8.9316.0 built by: NET481REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
System.Speech
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
Microsoft.Web.WebView2.WinForms
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Microsoft.Web.WebView2.WinForms.DLL
System.Memory
  Assembly Version: 4.0.1.2
  Win32 Version: 4.6.31308.01
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Memory.DLL
System.Runtime.CompilerServices.Unsafe
  Assembly Version: 4.0.4.1
  Win32 Version: 4.6.28619.01
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Runtime.CompilerServices.Unsafe.DLL
System.Buffers
  Assembly Version: 4.0.3.0
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Buffers.DLL
System.Web
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Net.Http
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
enabled.
For example:
<configuration>
</configuration>
SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)SkyDemon Team (700K reputation)
SkyDemon doesn't support loading KML files.
SkyDemon Plan (for your PC) does support opening more than one SkyDemon log file at once, so that would probably be the best solution.
Alternatively, you may be able to find a tool that merges multiple GPX files into each other. I presume that the one you're using already has produced some invalid output, judging by the error details you pasted. If you'd like us to look further into that please send the invalid output to our customer support by email, and I'll take a look.
