I have just been on a multi-leg trip around Europe and wanted to display this all on my Skydemon in the normal tracklog form.However because the flights were greater than 10 minutes apart I was unable to do this.
I imported all of my tracklog files into Google earth and used a converter tool which has put them all into 1 KML file which works beautifully. Id like to display this on the Skydemon map however and have been trying to use the "open from different location or with different filetype feature" to display that merged track.
It didn't recognise the KML files, so I converted those to GPX, which it did but then I had an error string as I tried to load it...
Any Ideas would be greatly appreciated!
System.NullReferenceException: Object reference not set to an instance of an object.
at Divelements.SkyDemon.IO.GarminMagellanExporter.GetGpxTrackSnapshot(XmlNode trkptNode, DateTime& startTime)
at Divelements.SkyDemon.IO.GarminMagellanExporter.GetFlightLogsFromGpx(XmlDocument d, WaypointManager waypointManager)
at Divelements.SkyDemon.frmMain.menuToolsOpenFlightLog_Activate(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9310.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SkyDemon
Assembly Version: 4.1.2.21099
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
Divelements.Aviation
Win32 Version: 4.1.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
Win32 Version: 4.8.9256.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.9032.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.Web.WebView2.Core
Assembly Version: 1.0.1518.46
Win32 Version: 1.0.1518.46
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Microsoft.Web.WebView2.Core.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.179.0
Win32 Version: 3.0.179.0
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.9316.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
System.Speech
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
Microsoft.Web.WebView2.WinForms
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Microsoft.Web.WebView2.WinForms.DLL
System.Memory
Assembly Version: 4.0.1.2
Win32 Version: 4.6.31308.01
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Memory.DLL
System.Runtime.CompilerServices.Unsafe
Assembly Version: 4.0.4.1
Win32 Version: 4.6.28619.01
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Runtime.CompilerServices.Unsafe.DLL
System.Buffers
Assembly Version: 4.0.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/System.Buffers.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Net.Http
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
enabled.
For example:
<configuration>
</configuration>
