Sample custom data
Baron von Mildred
Baron von Mildred
Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)Too Much Forum (7.4K reputation)
Posts: 78, Visits: 176
Does anyone have a sample custom data .csv file I could look at? I had a go at creating my own data file as per the tutorial, i.e. entering some data in a spreadsheet, then converting it to .csv, but the Skydemon software says 'input string not in correct format'. Just thought if I could see a file that works, I could work out what was wrong & correct it.
BVM
Sure, what data were you interested in? Airfields, obstructions?
Baron von Mildred
Baron von Mildred
As a first attempt I was trying to make a file for naviads. Once thats successful I intend to start building up the rest of the data for the area I fly (central Africa) i.e. airfields, airspace
Sure. Here's a file with three navaids from the UK data.
sample.radioaids.csv (619 views, 163 bytes)
Baron von Mildred
Baron von Mildred
Thanks for that Tim. I give it another try & report back. Sorry its taken a few days to reply, I don't get regular access to internet here in Africa!
No worries. We've actually created a graphical tool that makes it really easy to create SkyDemon data. Would you like to try a preview of it? If so, let me know by contacting me directly using the link at the bottom of the homepage and I'll email you a copy.
Baron von Mildred
Baron von Mildred
Thanks for the sample thats helped. If anyone else is having trouble with this, the problem was that when I created the .csv file from the spreadsheet it wanted to put commas & quotations around everything. I needed to force it to drop the quotations.
Anyone else having trouble getting custom data to load at start up? Loads fine on import now!
