Sample custom data
Baron von Mildred
Baron von Mildred
Posts: 78, Visits: 176
Does anyone have a sample custom data .csv file I could look at? I had a go at creating my own data file as per the tutorial, i.e. entering some data in a spreadsheet, then converting it to .csv, but the Skydemon software says 'input string not in correct format'. Just thought if I could see a file that works, I could work out what was wrong & correct it.
BVM
No worries. We've actually created a graphical tool that makes it really easy to create SkyDemon data. Would you like to try a preview of it? If so, let me know by contacting me directly using the link at the bottom of the homepage and I'll email you a copy.
Baron von Mildred
Baron von Mildred
Thanks for the sample thats helped. If anyone else is having trouble with this, the problem was that when I created the .csv file from the spreadsheet it wanted to put commas & quotations around everything. I needed to force it to drop the quotations.
Anyone else having trouble getting custom data to load at start up? Loads fine on import now!
