Multiple aircraft
jekroth
j
Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)
Posts: 21, Visits: 0
I fly several different airplanes and I usually forget to change the airplane profile before the flight.
When you have several aircraft profiles in skydemon's aircraft folder, I think it would be good that, when starting skydemon you have to choose which aircraft you intend to fly,
is it just me who experiences it as a problem
Gerhard66
G
Posts: 175, Visits: 358
Same problem … getting older… 🤷🏼‍♂️
I added an extra item to the before start checklists ☝️
Johannes B.
J
Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)Too Much Forum (824 reputation)
Posts: 54, Visits: 1
Also fly different planes,  but I have never encountered this issue, since choosing the correct plane is essential for performance-, fuel- as well as best altitude planning.
YouTube channel
jekroth
j
jekroth - 8/1/2025 7:39:29 PM
Once again sending flight plan with skydemon, should activate the flight plan after take off and it is not there. Nothing wrong with Skydemon, but it's me who didn't switch to the right aircraft profile. the flight plan was there but had the wrong registration number. It was an international flight so it was just a matter of landing send a new one, wait 8ch try again. Clancy Yes, but therefore it would be good that when starting skydemon you have the option to choose which aircraft profile you want to use
You can select which aircraft is in use in SkyDemon at any time. I see no reason why we should interrupt the user to force them to make a selection. I understand that you accidentally filed a flightplan using the wrong one, but you had multiple opportunities to check the data was correct before filing it.
If lots of people are encountering this issue, hopefully they'll contribute to this thread, and we investigate development work to alleviate the issue.
