Multiple aircraft
http://forums.skydemon.aero/Topic38260.aspx
By jekroth - 8/1/2025 7:39:29 PM
I fly several different airplanes and I usually forget to change the airplane profile before the flight.
When you have several aircraft profiles in skydemon's aircraft folder, I think it would be good that, when starting skydemon you have to choose which aircraft you intend to fly,
is it just me who experiences it as a problem
By Tim Dawson - 8/20/2025 9:31:07 AM
You can select which aircraft is in use in SkyDemon at any time. I see no reason why we should interrupt the user to force them to make a selection. I understand that you accidentally filed a flightplan using the wrong one, but you had multiple opportunities to check the data was correct before filing it.
If lots of people are encountering this issue, hopefully they'll contribute to this thread, and we investigate development work to alleviate the issue.
