New borders Padova FIC
giannisd
giannisd
Posts: 99, Visits: 173
AIRAC AMENDMENT 04/2025 start 17 aprile 2025
I settori FIC di Padova sono operativi dalle 07.00 alle 23.00 locali. Di notte il servizio FIS è erogato dai settori ACC: a nord-ovest 120.725 MHz, a sud-est 134.750 MHz.
Sulla mappa NOTAM è disponibile il layer dedicato “Settori FIC” per poter visualizzare con semplicità e su una mappa aeronautica i confini dei FIC italiani.
ROME FIS 4 Freq. 125.759, 119.075, 134.125, 129.575 the 119.075 is not depicted in your map.
Thanks. These areas have not been changed by AIRAC. Instead it appears (as before) that NOTAM have been used to change them with short notice. I believe we have now updated these areas.
giannisd
giannisd
Tim Dawson - 4/24/2025 9:48:17 AM
No Tim, was on Notam,  but now the 4 areas for each FIS Info Freq on Roma FIR are depicted on the:
ENR 2.1.1.2 ROMA FIR/UIR Roma FIC - FIS/ALRS the freq. of Roma Information day time VFR (0600-22.00) are indicated by area on the Note Remarks Column 7  :
125.750 Mhz area coordinates Note 14
119.075 Mhz area coordinates Note 10
134.125 Mhz area coordinates Note   9
129.575 Mhz area coordinates Note 11
On your map you divided the Roma Fir in 3 areas: 14, 9 and 11,  but the area 10 with 119.075 Mhz  is missed .
Is a small area the FIC eventually inform the pilots to change on the correct freq,  but accuracy is important !
regards,
Gianni
Thanks. I am going to look into this.
