New borders Padova FIC
giannisd
giannisd
Posts: 99, Visits: 174
AIRAC AMENDMENT 04/2025 start 17 aprile 2025
I settori FIC di Padova sono operativi dalle 07.00 alle 23.00 locali. Di notte il servizio FIS è erogato dai settori ACC: a nord-ovest 120.725 MHz, a sud-est 134.750 MHz.
Sulla mappa NOTAM è disponibile il layer dedicato “Settori FIC” per poter visualizzare con semplicità e su una mappa aeronautica i confini dei FIC italiani.
ROME FIS 4 Freq. 125.759, 119.075, 134.125, 129.575 the 119.075 is not depicted in your map.
Posts: 8.3K, Visits: 9.8K
Thanks. These areas have not been changed by AIRAC. Instead it appears (as before) that NOTAM have been used to change them with short notice. I believe we have now updated these areas.
giannisd
giannisd
Tim Dawson - 4/24/2025 9:48:17 AM
No Tim, was on Notam,  but now the 4 areas for each FIS Info Freq on Roma FIR are depicted on the:
ENR 2.1.1.2 ROMA FIR/UIR Roma FIC - FIS/ALRS the freq. of Roma Information day time VFR (0600-22.00) are indicated by area on the Note Remarks Column 7  :
125.750 Mhz area coordinates Note 14
119.075 Mhz area coordinates Note 10
134.125 Mhz area coordinates Note   9
129.575 Mhz area coordinates Note 11
On your map you divided the Roma Fir in 3 areas: 14, 9 and 11,  but the area 10 with 119.075 Mhz  is missed .
Is a small area the FIC eventually inform the pilots to change on the correct freq,  but accuracy is important !
regards,
Gianni
Thanks. I am going to look into this.
