Visits: 1.9K
Tim,
Although I always get there in the end, I do find installing updates to InFlight a bit tricky, even with the new installer (this is on a Loox). There are two things in particular that I'm unsure of. Firstly, do I need to delete the old SkyDemon first? I would have thought not, but I have ended up with both old and new versions installed. Secondly, if after updating I find I'm back to an evaluation version, what have I done wrong? Should I have downloaded the license again first?
I'd appreciate guidance on this. At present I'm much more plug'n'pray than plug'n'play.
On the plus side, once I got it up and running, both Plan and InFlight 1.1 seem to have some very useful improvements. Keep them coming!
